Power Macintosh G3 Minitower Processor Heatsink Clip Replacement
Выберете то, что вам нужно
    • Press the green release button on top of the side access panel.
    • Pull off the side access panel to get inside the computer.
    • When putting the side access panel back on, make sure that the bottom of the panel lines up with the rail on the bottom, and that the chassis is locked with the green latches.
    • Lay the computer on its side, ensuring that where the side access panel was is facing up.
    • Unlock the top chassis by moving the two green locking latches upward and outward.
    • Using the handle, gently swing the top chassis up and out until it rests firmly on the work surface.
    • While pressing down on the top of the processor heatsink clip, use a metal spudger or flathead screwdriver to lift up on the front tab of the clip and release it.
    • Remove the clip.
Заключение
LeoI07
Участник с: 06/10/21
1 573 Репутация
Автор 17 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 8
За всё время: 99
