Выберете то, что вам нужно
Press the green release button on top of the side access panel.
Pull off the side access panel to get inside the computer.
Lay the computer on its side, ensuring that where the side access panel was is facing up.
Unlock the top chassis by moving the two green locking latches upward and outward.
Using the handle, gently swing the top chassis up and out until it rests firmly on the work surface.
Using a Phillips screwdriver, unscrew the screw on the logic board holding the processor module wire in place.
