Введение
This guide will show you how to replace the power and 3.5 mm audio adapter jacks on an iHome iP37.
Выберете то, что вам нужно
Инструмент, используемый на этом этапе:iOpener$19.99
Pry the exterior housing off the iHome iP37. You may need extra leverage to do this.
Remove these four 9 mm screws from the plastic casing; you will need a Phillips #2 driver to do this.
Remove the flanged 9 mm screw from the counterweight; you will need a Phillips #2 driver to do this.
Lift and remove the counterweight.
Firmly and cautiously unplug the two white 3-pin connectors from the printed circuit board.
Remove the two 5mm screws holding the power and 3.5mm jack PCB onto the rest of the device; you will need a Phillips #1 driver to do this.
Lift the PCB away from the rest of the device.
