Введение
This guide will teach you how to power your phone on.
Reach up to the top of the device.
Press and hold the power button for 3 seconds.
Your device should now be on.
If it doesn't turn on:
Make sure you held the power button long enough.
Connect the charger (The battery may be flat)
Make sure a battery is present in the battery slot.
If all else fails, refer to instruction manual or contact HTC Customer support.
To turn the device off: 1. Unlock the Device 2. Hold the power button (3 secs) 3. Tap on the "Power Off" Button
20 человек успешно провели ремонт по этому руководству.
2 Комментарии к руководству
Comment changé l'écran tactile HTC désire hd
ha....hahaha :) having a bad time and then this! gonna be a good night,
