Введение
This guide will show you how to access and replace the L and R thumbstick covers on your PowerA Enhanced Wireless Controller. If your thumbsticks are sticking or causing drift, you may need to remove the covers to clean or replace them. Replacing worn-out thumbstick covers can improve gameplay performance.
The components involved in this replacement are small, so a steady hand and good organization are essential. Performing this repair yourself can save both time and money. Be sure to purchase the correct replacement parts in advance from the Xbox website or a local gaming store.
Выберете то, что вам нужно
Remove the battery cover by pressing down on the lever located on the top of the cover.
Apply pressure until it clicks out of place, and pull it off.
Insert the iFixit opening tool into the seam and gently pry the cover plate up.
Remove the cover plate once it is loosened.
Remove all three screws securing the motherboard using the J00 screwdriver.
Remove the motherboard.
13 человек успешно провели ремонт по этому руководству.
21 Комментарии к руководству
My controllers are drifting, What can i do after getting the joystick of to fix that.
i dont know i cleaned using plush sticks ( that usually go to ears that one ) i used that and isopropacol alcohoc 90%
it works for 2 weeks ( on me ) and now my Right analog stick is too Loose to wiggle there
BrunoS -
Where can I get replacement thumbsticks for this controller? Are they the same as the Switch Pro Controllers?
i need replacement joy-sticks too
BrunoS -
I need a link for the thumbsticks too. Cant seem to find them anywhere and PowerA does no sell them nor is willing to help.
