Введение
This guide will show you how to access and replace the motherboard of your PowerA Enhanced Wireless Controller for Nintendo Switch. Replacing the motherboard is a necessary step for fixing stick drift and power-related issues on your controller. Other motherboard issues are often characterized by unresponsive buttons and your controller failing to immediately turn on.
Before beginning the repair process, it's important to remove the batteries from your controller to ensure your safety during the repair and prevent any additional issues. Step 1 of this guide will show you how to access the battery compartment to remove the batteries.
Выберете то, что вам нужно
Remove the battery cover by pressing down on the lever located on the top of the cover.
Apply pressure until it clicks out of place, and pull it off.
Insert the iFixit opening tool into the seam and gently pry the cover plate up.
Remove the cover plate once it is loosened.
Remove all three screws securing the motherboard using the J00 screwdriver.
Remove the motherboard.
2 участников успешно повторили данное руководство.
Один комментарий
Je cherche un couvercle de batterie pour ma manette switch
Auriez-vous un site où il est possible de s’en procurer un ?
Merci
