Введение
You can easily remove the floppy drive in order to repair or upgrade it.
Инструменты
No tools required.
Запчасти
Никакие детали не требуются.
  1. Close the screen and turn the PowerBook over. Orient the computer so the text of the label is right side up.
    • Close the screen and turn the PowerBook over. Orient the computer so the text of the label is right side up.
  2. Free shipping on all orders over 100 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  3. Press and hold the button on the left of the front side, and slide the battery out. Press and hold the button on the left of the front side, and slide the battery out.
    • Press and hold the button on the left of the front side, and slide the battery out.
  4. First, slide the switch on the back of the computer to the left. Then pull the floppy drive out of the computer.
    • First, slide the switch on the back of the computer to the left.
    • Then pull the floppy drive out of the computer.
Заключение
Michael Mondragon
Участник с: 12.04.2011
115 Репутация
Автор 9 руководств
Команда
Cal Poly, Team 24-59, Amido Spring 2011 Member of Cal Poly, Team 24-59, Amido Spring 2011
CPSU-AMIDO-S11S24G59
4 членов
Автор 9 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 1
За 7 дней: 2
За 30 дней: 3
За всё время: 1,565
