PowerBook G3 Lombard Modem Replacement
Выберете то, что вам нужно
  1. PowerBook G3 Lombard Modem Replacement, Keyboard: шаг 1, изображение 1 из 1
    • Turn the computer so that the ports are facing you.
    • If the keyboard is locked, open the port cover and turn the keyboard locking screw until the keyboard is unlocked.
  2. PowerBook G3 Lombard Modem Replacement: шаг 2, изображение 1 из 1
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    • Make sure you have removed the laptop battery and CD/DVD module from the expansion bays before proceeding.
  3. PowerBook G3 Lombard Modem Replacement: шаг 3, изображение 1 из 1
    • Lift the keyboard out by pulling it up and away from you. Rest the keyboard, face down, on top of the trackpad.
    • In order to replace the keyboard, you must first remove the modem.
  4. PowerBook G3 Lombard Modem Replacement, Heat Shield: шаг 4, изображение 1 из 1
    • Remove the three silver Phillips screws that attach the heat shield to the internal metal framework.
  5. PowerBook G3 Lombard Modem Replacement: шаг 5, изображение 1 из 1
    • Lift the heat shield up and pull it toward you.
  6. PowerBook G3 Lombard Modem Replacement: шаг 6, изображение 1 из 1
    • Your laptop should look approximately like this.
  7. PowerBook G3 Lombard Modem Replacement, PRAM Battery: шаг 7, изображение 1 из 1
    • Pull the battery cable directly up from the logic board.
  8. PowerBook G3 Lombard Modem Replacement: шаг 8, изображение 1 из 1
    • Remove the battery from its holder by pulling up and to the left.
  9. PowerBook G3 Lombard Modem Replacement, Modem: шаг 9, изображение 1 из 1
    • Remove the two silver Phillips screws from the modem.
  10. PowerBook G3 Lombard Modem Replacement: шаг 10, изображение 1 из 1
    • Use a spudger, the tips of your fingers, or a flat non-metal tool to get under the modem's edge and pry it up from its socket as shown in the picture.
  11. PowerBook G3 Lombard Modem Replacement: шаг 11, изображение 1 из 1
    • Disconnect the cable from the right side of the modem.
  12. PowerBook G3 Lombard Modem Replacement: шаг 12, изображение 1 из 1
Заключение
3 участников успешно повторили данное руководство.
Прикрепленные документы
iRobot
Участник с: 09/24/09
1 Репутация
Автор 636 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 2,808
