PowerBook G3 Pismo Airport Card Replacement
Выберете то, что вам нужно
  1. PowerBook G3 Pismo Airport Card Replacement, Keyboard: шаг 1, изображение 1 из 1
    • Turn the keyboard locking screw so that it is parallel to the space bar.
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    • Lift the keyboard out by pulling it up and away from you. Rest the keyboard, face down, on top of the track pad.
    Спросите у FixBot
    Добавить комментарий
  2. PowerBook G3 Pismo Airport Card Replacement: шаг 2, изображение 1 из 1
    • Pull the keyboard ribbon straight up from the logic board. Place the keyboard aside.
    • The connector may be tight. Gently rock the connector from side to side while pulling directly upward to free it. You can use this technique on many of the cards and cables you'll be disconnecting.
    • Make sure you have removed the laptop battery and CD/DVD modules from the expansion bays before proceeding.
    Спросите у FixBot
  3. PowerBook G3 Pismo Airport Card Replacement: шаг 3, изображение 1 из 1
    • Your laptop should look approximately like this.
    Спросите у FixBot
  4. PowerBook G3 Pismo Airport Card Replacement, Heat Shield: шаг 4, изображение 1 из 1
    • Remove the two silver Phillips #1 screws that attach the heat shield to the internal metal framework.
    • Lift the heat shield up and pull it toward you.
    Спросите у FixBot
  5. PowerBook G3 Pismo Airport Card Replacement: шаг 5, изображение 1 из 1
    Спросите у FixBot
  6. PowerBook G3 Pismo Airport Card Replacement, Airport Card: шаг 6, изображение 1 из 1
    • Skip this step if your computer does not have an Airport card installed.
    • Firmly grasp the plastic tab attached to the Airport card and pull up and then to the right.
    • The Airport card is still attached to the antenna cable, so don't just yank it out of the slot.
    Спросите у FixBot
  7. PowerBook G3 Pismo Airport Card Replacement: шаг 7, изображение 1 из 1
    • Disconnect the antenna cable from the Airport card.
    Спросите у FixBot
Заключение
18 человек успешно провели ремонт по этому руководству.
Прикрепленные документы
iRobot
Участник с: 09/24/09
1 Репутация
Автор 636 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 15
За последние 30 дней: 81
За всё время: 20,511
