Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
The time and date, as well as other settings, are kept by the PRAM battery when your machine is off.
Выберете то, что вам нужно
Turn the keyboard locking screw so that it is parallel to the space bar.
Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
Lift the keyboard out by pulling it up and away from you. Rest the keyboard, face down, on top of the track pad.
Pull the keyboard ribbon straight up from the logic board. Place the keyboard aside.
Remove the two silver Phillips #1 screws that attach the heat shield to the internal metal framework.
Lift the heat shield up and pull it toward you.
Firmly grasp the plastic tab attached to the Airport card and pull up and then to the right.
Pull the battery cable directly up from the logic board.
Remove the battery from its holder by pulling up and to the left.
24 участников успешно повторили данное руководство.
Прикрепленные документы
6 Комментариев
Frankly speaking I do not have idea why do I need steps 2-7 to replace battery? Why I can't go directly to step 8 if it is possible? BTW - the battery seems to be composed from 4 standard batteries. Is anyone aware how to assembly new battery? It is not available as spare part (616-0108)
Agreed, I just successfully removed my PRAM battery skipping all those steps, just popped the keyboard out, removed the DVD drive from the right-hand out and popped that bad boy out, no problemo.
I read that you "removed the DVD drive from the right-hand out...." I'm baffled as to what you mean or how that is done. Can you explain that step?
Why do I need to remove the airport card? It's just like telling somebody to remove their shoes to take off their hat?
