PowerBook G3 Pismo Processor Replacement
Выберете то, что вам нужно
  1. PowerBook G3 Pismo Processor Replacement, Keyboard: шаг 1, изображение 1 из 1
    • Turn the keyboard locking screw so that it is parallel to the space bar.
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    • Lift the keyboard out by pulling it up and away from you. Rest the keyboard, face down, on top of the track pad.
  2. PowerBook G3 Pismo Processor Replacement: шаг 2, изображение 1 из 1
    • Pull the keyboard ribbon straight up from the logic board. Place the keyboard aside.
    • The connector may be tight. Gently rock the connector from side to side while pulling directly upward to free it. You can use this technique on many of the cards and cables you'll be disconnecting.
    • Make sure you have removed the laptop battery and CD/DVD modules from the expansion bays before proceeding.
  3. PowerBook G3 Pismo Processor Replacement: шаг 3, изображение 1 из 1
    • Your laptop should look approximately like this.
  4. PowerBook G3 Pismo Processor Replacement, Heat Shield: шаг 4, изображение 1 из 1
    • Remove the two silver Phillips #1 screws that attach the heat shield to the internal metal framework.
    • Lift the heat shield up and pull it toward you.
    On my M7572, these are T9s not Philips.
    Rufleyboy - Ответить
  5. PowerBook G3 Pismo Processor Replacement: шаг 5, изображение 1 из 1
  6. PowerBook G3 Pismo Processor Replacement, Airport Card: шаг 6, изображение 1 из 1
    • Skip this step if your computer does not have an Airport card installed.
    • Firmly grasp the plastic tab attached to the Airport card and pull up and then to the right.
    • The Airport card is still attached to the antenna cable, so don't just yank it out of the slot.
    On mine, the airport card had been put it with the orange ribbon OVER the top, so had to unplug the righthand connector and then plug it back in after (see pic for Step 8)
  7. PowerBook G3 Pismo Processor Replacement: шаг 7, изображение 1 из 1
    • Disconnect the antenna cable from the Airport card.
  8. PowerBook G3 Pismo Processor Replacement, PRAM Battery: шаг 8, изображение 1 из 1
    • Pull the battery cable directly up from the logic board.
    • Remove the battery from its holder by pulling up and to the left.
  9. PowerBook G3 Pismo Processor Replacement: шаг 9, изображение 1 из 1
  10. PowerBook G3 Pismo Processor Replacement, Heat Sink: шаг 10, изображение 1 из 1
    • Remove the long silver Phillips #1 screw from the heat sink.
    • Remove the two T8 Torx screws that attach the heat sink to the processor.
  11. PowerBook G3 Pismo Processor Replacement: шаг 11, изображение 1 из 1
    • Lift the heat sink up from the left side and pull it out.
    • If you need to mount the heat sink back into the laptop, we have a thermal paste guide that makes replacing the thermal compound easy.
  12. PowerBook G3 Pismo Processor Replacement, Processor: шаг 12, изображение 1 из 1
    • Grasp the plastic tab on the processor's right side and pull it directly up.
    • Some processors may be missing the plastic pull tab. In this case, we suggest using a non-metal tool to gently pry up the processor. Slip the tool's thin edge under the front right corner of the processor and carefully pry it up.
  13. PowerBook G3 Pismo Processor Replacement: шаг 13, изображение 1 из 1
Заключение
8 участников успешно повторили данное руководство.
Прикрепленные документы
iRobot
Участник с: 09/24/09
1 Репутация
Автор 636 руководств
Один комментарий
i know how to fix the processor but i have heard of much more powerful upgrades
Roman - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 5
За последние 30 дней: 11
За всё время: 9,007
