Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
The Power Management Unit is located on the bottom of the upper case.
  1. Remove both expansion bay modules using the levers on the front of the computer.
    • Remove both expansion bay modules using the levers on the front of the computer.
    • Insert your index fingers inside the expansion bays and search for the two ribbed tabs on the underside of the upper case. The tabs are located near the bottom corners of the keyboard.
    • Pull the tabs toward yourself and the keyboard will pop up.
  2. Pull the keyboard forward to disengage the tabs holding it in back and rotate it toward you.
    • Pull the keyboard forward to disengage the tabs holding it in back and rotate it toward you.
    • Rest the keyboard on the trackpad.
    • This is a diagram of the ribbon clamp connectors you will disconnect in the next step.
    • 1) With your fingernails, grasp the locking bar on either side and pull up a small amount (about 1/16" or 2 mm).
    • 2) After disengaging the locking bar, slide the cable out of the connector.
  3. Disconnect the two keyboard connectors by disengaging the clamps and pulling the ribbons directly upward.
    • Disconnect the two keyboard connectors by disengaging the clamps and pulling the ribbons directly upward.
  4. Slide a spudger downward between each plastic strain relief cable and the wall of the case in order to bow out the cable beyond the small tab holding it in place.
    • Slide a spudger downward between each plastic strain relief cable and the wall of the case in order to bow out the cable beyond the small tab holding it in place.
    • Once the strain relief cables are free, lift the keyboard off.
  5. Your laptop should look approximately like this.
    • Your laptop should look approximately like this.
  6. Remove the two Phillips screws from the heat shield.
    • Remove the two Phillips screws from the heat shield.
    • One screw is shorter than the other. When putting the Wallstreet back together, this screw goes in the middle of the heat shield.
  7. Grasp the metal handle on the heat shield and pull up and toward yourself.
    • Grasp the metal handle on the heat shield and pull up and toward yourself.
  8. Unscrew, but do not remove, the single Phillips screw from the hard drive bracket.
    • Unscrew, but do not remove, the single Phillips screw from the hard drive bracket.
  9. Grasp the hard drive bracket on the left side and pull up and to the left.
    • Grasp the hard drive bracket on the left side and pull up and to the left.
  10. Your laptop should look approximately like this.
  11. Use a spudger, the tips of your fingers, or a flat non-metal tool to pry up the processor's right side.
    • Use a spudger, the tips of your fingers, or a flat non-metal tool to pry up the processor's right side.
    • Remove the processor by sliding it up and to the right.
    • The processor and RAM can be removed as a unit. It is not necessary to remove the RAM from the processor.
    • There are two tabs on the left side of the processor that fit into slots on the metal framework. Make sure these tabs are in the slots.
  12. Remove the single Phillips screw from the modem.
    • Remove the single Phillips screw from the modem.
    • Disconnect the orange PMU cable by pulling it directly up.
  13. Disconnect the modem from the logic board by lifting up on the right side using a spudger, the tip of your finger, or a flat non-metal tool.
    • Disconnect the modem from the logic board by lifting up on the right side using a spudger, the tip of your finger, or a flat non-metal tool.
    • Remove the modem by sliding it up and to the right.
  14. Your laptop should look approximately like this.
  15. Push the display back so that it lies flat.
    • Push the display back so that it lies flat.
    • Slip a spudger or your index finger under the clutch cover near the power button and pull upward until you feel it come free.
    • Repeat the previous step on the left side.
  16. Lift the clutch cover off by rotating it up and then toward you.
    • Lift the clutch cover off by rotating it up and then toward you.
  17. Disconnect the orange display data cable on the left side of the computer. Grasp the cable near the connector and pull directly up.
    • Disconnect the orange display data cable on the left side of the computer. Grasp the cable near the connector and pull directly up.
  18. Disconnect the orange display inverter cable on the right side of the computer. Grasp the cable near the connector and pull directly up.
    • Disconnect the orange display inverter cable on the right side of the computer. Grasp the cable near the connector and pull directly up.
    • Make sure that both cables are free from the plastic casing before proceeding to the next step.
  19. Turn the laptop around so that its back faces you.
    • Turn the laptop around so that its back faces you.
    • Open the port door located at the back of the laptop.
    • Remove the four black T8 Torx screws.
  20. Turn the laptop back around so that the screen faces you.
    • Turn the laptop back around so that the screen faces you.
    • Adjust the display so that it is in a vertical position.
    • Hold the display on both sides and pull directly up until its hinges are free of their mounts
  21. Your laptop should look like this.
    • Your laptop should look like this.
  22. Remove the four T8 Torx screws from the upper case.
    • Remove the four T8 Torx screws from the upper case.
  23. Turn the laptop over.
    • Turn the laptop over.
    • Remove the eight T8 Torx screws from the bottom casing.
    • There are two longer screws in the front left and front right corners; make sure to put them back in the proper place when reassembling.
  24. Turn the laptop over.
    • Disengage the small locking tab by pressing in on the upper case to the right of the PMU connector.
    • Lift the upper case up just enough so that the tab rests on its metal bracket.
  25. Grasp the upper case near the back left corner and lift up partly so that you can access and disconnect the audio in/out cable from the sound card in the upper right corner of the case.
    • Grasp the upper case near the back left corner and lift up partly so that you can access and disconnect the audio in/out cable from the sound card in the upper right corner of the case.
    • Be careful not to lift the upper casing too far before you have disconnected the audio in/out cable.
    • Remove the upper casing. Note that there are two tabs on the laptop's front that often cause the upper case to stick.
  26. Your laptop should look approximately like this.
  27. Disconnect the multicolor cable from the right side of the PMU.
    • Disconnect the multicolor cable from the right side of the PMU.
  28. Free the battery cable from the upper case.
    • Free the battery cable from the upper case.
  29. Use a spudger or the tips of your fingers to pry up the PRAM battery and free it from its housing.
    • Use a spudger or the tips of your fingers to pry up the PRAM battery and free it from its housing.
  30. Remove the single T8 Torx screw from the front left corner of the PMU.
    • Remove the single T8 Torx screw from the front left corner of the PMU.
    • Lift up the front edge of the PMU and disconnect the three smaller orange ribbon cables (two on the left side of the large PMU cable, and one on the right side) that attach to the underside of the PMU from the upper case.
  31. Turn the upper case over and pull the PMU connector cable up from the upper case.
    • Turn the upper case over and pull the PMU connector cable up from the upper case.
  32. Turn the upper case back over and slide the PMU out.
    • Turn the upper case back over and slide the PMU out.
Заключение
3 участников успешно повторили данное руководство.
Прикрепленные документы
iRobot
Участник с: 24.09.2009
1 Репутация
Автор 648 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 5,211
