Введение
56k internal modem, standard on all models.
Выберете то, что вам нужно
Use a coin to turn the battery locking screw 90 degrees clockwise.
Lift the battery out of the computer.
Remove the four Phillips screws from the memory door.
Slide the memory door away from the memory compartment.
Remove the following 8 screws:
Two 3 mm Phillips in the battery compartment, on either side of the battery contacts.
Two 9 mm Phillips on either side of the memory compartment.
Four 16 mm Phillips along the hinge.
Rotate the computer 90 degrees clockwise, so that the power receptacle faces you.
Remove the three 3 mm Phillips screws.
Turn the computer 90 degrees clockwise so that the hinge faces you.
Remove the bottom 5 mm Phillips screw on either side of the hinge (two total).
Rotate the computer 90 degrees clockwise, so that the ports face you.
Turn the computer over and open the display.
Remove the 4.2 mm 1/16" H 1.5 hex screws in either corner, next to the display (a T6 Torx driver will also do the job nicely).
Grasp the back corners of the upper case and pull up, disengaging hidden tabs on the sides. Do not pull the upper case off yet; you still need to free tabs in the front of the case.
Pry up the left side of the upper case slightly with your hand and wedge a spudger into the seam between the upper case and lower case.
Leave the tool in place applying pressure to the upper case for the next step.
Place enough pressure on the upper case to allow you to slide a tool just within the seam between upper case and lower case as shown in the picture. A dentist's hook, push pin, or similar tool will work.
Delicately slip the tip of your tool behind the silver metal latch and pull it forward while pulling up on the case. This may take some effort.
Alternatively, you can free the clasp with a small flathead screwdriver through the CD slot. The clasp is 1-3/16 in (3cm) from the left side of the slot. Use the screwdriver to lift out (or press back) the felt lining; then use the screwdriver to pull the clasp (shiny metal) forward to free it from the catch behind it (dull metal).
Lift the back of the case up and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case.
Rotate the upper case up and toward the screen, so that the upper case rests against it.
Remove the orange tape securing the trackpad ribbon to the logic board.
Disconnect the trackpad ribbon from the logic board.
1) With your fingernails, grasp the locking bar on either side and pull up a small amount (about 1/16" or 2 mm).
2) After disengaging the locking bar, slide the cable out of the connector.
Loosen the keyboard ribbon clamp by pushing the thin black piece toward the screen, using the tips of your fingers.
Slide the grey keyboard ribbon out of the loosened connector.
Remove the upper case from the computer.
Remove the two 6 mm long silver Phillips screws from the metal bracket to the right of the hard drive, removing tape as necessary.
Disconnect the large orange hard drive cable from the logic board, removing tape as necessary.
Deroute the red and black speaker cable from under the fold in the hard drive ribbon.
Close the display and turn the hinge side of the computer to face you.
Remove the remaining Phillips screw on either side of the hinge (two screws total).
Open the computer with the display facing you.
Use a spudger to pry the bluetooth board from the gap between the battery housing and front of the lower case.
Disconnect the bluetooth antenna cable from the bluetooth board.
Deroute the bluetooth antenna cable along the left edge of the computer, removing tape as necessary.
Pull the Airport ribbon cable up in order to access the black Airport antenna connector.
Disconnect the Airport antenna cable at the black connector, making sure you pull only on the black rubber portion of the connector.
Remove the two pieces of orange tape covering the display data cable and disconnect the cable from the logic board.
Remove the T8 Torx screw closer to the display on either side of the hinge (two screws total).
Disconnect the indicated 14 cables from the logic board, starting in one place and moving around the board.
Remove the following 12 Phillips screws from the logic board:
Six 4 mm around the edges of the logic board.
Two 5 mm securing the right speaker to the logic board (move the speaker off of the logic board).
Three 6 mm with wavy washers in the upper, left corner of the logic board.
One 4 mm underneath a black bumper in the back right corner of the logic board.
One 4 mm screw may not be present on some logic boards.
Grasp the logic board at the left edge with one hand and at the thinnest section with the other hand. Lift the left edge of the board up to approximately a 30 degree angle (if you don't have your protractor handy, just lift until the DVI port clears the right hinge).
Once the logic board clears the ports, slide it out to the left.
Use a firm plastic edge to scrape the thermal material off the processor.
For more advanced instructions on this procedure, see our Applying Thermal Paste Guide.
Remove the two black Phillips screws from the yellow plastic board above the USB port on the left side of the computer.
Remove the black Phillips screw on the bottom corner of the left speaker board.
Lift the speaker board up from the computer so that you can access and disconnect the speaker cable from the sound board.
Remove the speaker assembly entirely, including the right speaker.
Remove the Phillips screw from each corner of the PC card cage (4 screws total).
Remove the following 7 Phillips screws attaching the heat sink to the metal framework:
Five 5 mm screws scattered around the heat sink.
One 6 mm on the front left corner of the heat sink.
One 10 mm in the back left corner of the left fan.
Remove the heat sink from the case, minding the left corner, as it tends to catch in the case (the fans will come out with the heat sink).
Disconnect the 4-pin power cable and orange ribbon from the DC/Sound card.
Remove the T8 Torx screw from the RJ-11 board.
Remove the 5 mm standoff that secures the DC/Sound card to the lower case using a nut driver or pliers.
Disconnect the Bluetooth cable from the DC/Sound card, removing tape as necessary.
Use your thumbs to slide the RJ-11 board away from the sound card in the same direction you would disconnect a cable. This is your chance to get out some aggression, as the board will most likely be very tight and requires a good deal of force to remove. Don't get carried away though - don't hold onto the power connector and don't put too much actual force on the card itself.
2 участников успешно повторили данное руководство.
