ΠŸΠ΅Ρ€Π΅ΠΉΡ‚ΠΈ ΠΊ основному ΡΠΎΠ΄Π΅Ρ€ΠΆΠ°Π½ΠΈΡŽ
Π’Π²Π΅Π΄Π΅Π½ΠΈΠ΅
56k internal modem, standard on all models.
Π˜Π½ΡΡ‚Ρ€ΡƒΠΌΠ΅Π½Ρ‚Ρ‹
Запчасти
  1. Use a coin or a spudger to turn the battery locking screw 90 degrees clockwise.
    • Use a coin or a spudger to turn the battery locking screw 90 degrees clockwise.
    • Lift the battery out of the computer.
  2. Remove the four Phillips screws from the memory door.
    • Remove the four Phillips screws from the memory door.
    • Slide the memory door away from the memory compartment.
  3. Remove the following 8 screws:
    • Remove the following 8 screws:
    • Two 3 mm Phillips in the battery compartment, on either side of the battery contacts.
    • Two 12 mm Phillips on either side of the memory compartment.
    • Four 16 mm Phillips along the hinge.
  4. Rotate the computer 90 degrees clockwise, so that the power receptacle faces you.
    • Rotate the computer 90 degrees clockwise, so that the power receptacle faces you.
    • Remove the three 3 mm Phillips screws.
    • When replacing these screws, you must place each screw in the correct order. Begin by installing the screw closest to the display hinge, and go out from there.
  5. Turn the computer 90 degrees clockwise so that the hinge faces you.
    • Turn the computer 90 degrees clockwise so that the hinge faces you.
    • Remove the bottom 5 mm Phillips screw on either side of the hinge (two total).
  6. Rotate the computer 90 degrees clockwise, so that the ports face you.
    • Rotate the computer 90 degrees clockwise, so that the ports face you.
  7. Turn the computer over and open the display.
    • Turn the computer over and open the display.
    • Remove the two 1.5 mm hex screws in either corner, next to the display (a T6 Torx driver will work, but repeated use will strip the screws).
  8. Grasp the back corners of the upper case and pull up. Do not pull the upper case off yet; you still need to disconnect the keyboard and trackpad cable.
    • Grasp the back corners of the upper case and pull up. Do not pull the upper case off yet; you still need to disconnect the keyboard and trackpad cable.
    • Lift the back of the case up and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case.
  9. Rotate the upper case up and toward the screen, so that the upper case rests against it.
    • Rotate the upper case up and toward the screen, so that the upper case rests against it.
  10. Remove the orange tape securing the trackpad ribbon to the logic board.
    • Remove the orange tape securing the trackpad ribbon to the logic board.
    • Disconnect the trackpad ribbon from the logic board.
    • Remove the upper case from the computer.
  11. Remove the three long silver Phillips screws from the retaining bracket on the left side of the optical drive.
    • Remove the three long silver Phillips screws from the retaining bracket on the left side of the optical drive.
    • Remove the retaining bracket.
  12. Disconnect the large orange hard drive cable from the logic board, removing tape as necessary.
    • Disconnect the large orange hard drive cable from the logic board, removing tape as necessary.
  13. Lift the hard drive up from the right side and remove it from the computer.
    • Lift the hard drive up from the right side and remove it from the computer.
  14. Remove the two silver Phillips screws from the modem board.
    • Remove the two silver Phillips screws from the modem board.
    • The screw in the top left corner has a black washer.
  15. Disconnect the large orange ribbon cable from the top of the modem.
    • Disconnect the large orange ribbon cable from the top of the modem.
  16. Lift the modem up and disconnect the remaining cable, at which point the modem will be free.
    • Lift the modem up and disconnect the remaining cable, at which point the modem will be free.
Π—Π°ΠΊΠ»ΡŽΡ‡Π΅Π½ΠΈΠ΅
ΠŸΡ€ΠΈΠΊΡ€Π΅ΠΏΠ»Π΅Π½Π½Ρ‹Π΅ Π΄ΠΎΠΊΡƒΠΌΠ΅Π½Ρ‚Ρ‹
iRobot
Участник с: 24.09.2009
1 РСпутация
Автор 646 руководств
ΠšΠΎΠΌΠΌΠ΅Π½Ρ‚Π°Ρ€ΠΈΠ΅Π²: 0
Π”ΠΎΠ±Π°Π²ΠΈΡ‚ΡŒ ΠΊΠΎΠΌΠΌΠ΅Π½Ρ‚Π°Ρ€ΠΈΠΉ
ΠŸΡ€ΠΎΡΠΌΠΎΡ‚Ρ€ статистики:
Π—Π° послСдниС 24часов: 0
Π—Π° послСдниС 7 Π΄Π½Π΅ΠΉ: 0
Π—Π° послСдниС 30 Π΄Π½Π΅ΠΉ: 5
Π—Π° всё врСмя: 2,756
