Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Replace your optical drive to regain disk-reading ability.
Выберете то, что вам нужно
Use your thumbs to push the two battery retaining tabs away from the battery.
The battery should pop up enough to rotate it toward yourself and lift it out of the lower case.
Remove the three 2.3 mm Phillips screws securing the memory cover to the lower case.
Lift the memory cover slightly and pull it toward yourself to remove it from the lower case.
Remove the following ten screws:
Two 14.7 mm shouldered Phillips.
Three 12.3 mm Phillips.
One 3.8 mm T8 Torx.
One 6.8 mm T8 Torx.
Three 1.3 mm Phillips.
Use your fingernails to separate the ZIF cable lock away from its socket. (Move the two brown bits down 1mm)
Remove the four 3.4 mm Phillips screws from the DVI connector side of the PowerBook.
Starting near the display, lift the upper case straight up off the lower case, minding any cables that may get caught.
Use the flat end of a spudger to pry the optical drive cable connector up off the logic board.
Remove the following four screws securing the optical drive to the lower case:
Three 6.8 mm T8 Torx.
One 3.8 mm T8 Torx.
Lift the optical drive out of the lower case, being careful not to disturb the PRAM battery & USB board ribbon cable.
Use the flat end of a spudger to separate the optical drive connector from the optical drive.
If necessary, pull the optical drive cable away from the optical drive.
Remove the two Phillips screws holding the optical drive bracket to the side of the optical drive.
Pull the optical drive bracket away from the thin side of the optical drive.
Remove the two Phillips screws securing the flat optical drive bracket to the side of the optical drive.
Remove the optical drive bracket.
4 участников успешно повторили данное руководство.
