Введение
Replace your sound card to regain audio functionality.
Выберете то, что вам нужно
Use your thumbs to push the two battery retaining tabs away from the battery.
The battery should pop up enough to rotate it toward yourself and lift it out of the lower case.
Remove the three 2.3 mm Phillips screws securing the memory cover to the lower case.
Lift the memory cover slightly and pull it toward yourself to remove it from the lower case.
Remove the following ten screws:
Two 14.7 mm shouldered Phillips.
Three 12.3 mm Phillips.
One 3.8 mm T8 Torx.
One 6.8 mm T8 Torx.
Three 1.3 mm Phillips.
Use your fingernails to separate the ZIF cable lock away from its socket. (Move the two brown bits down 1mm)
Remove the four 3.4 mm Phillips screws from the DVI connector side of the PowerBook.
Starting near the display, lift the upper case straight up off the lower case, minding any cables that may get caught.
Use the flat end of a spudger to pry the sound card ribbon cable connector up off the logic board.
Move the sound card ribbon cable away from the face of the hard drive.
Use the flat end of a spudger to pry the hard drive ribbon cable connector up off the logic board.
Remove the following four screws:
Three 11.1 mm T8 Torx.
One 3.9 mm T8 Torx.
Lift the hard drive out of the lower case.
Pull the speaker cable connector straight up to disconnect it from the sound card.
Use the flat end of a spudger to pry the USB sockets away from the left edge of the lower case.
Lift the sound card slightly out of the lower case, minding the fragile lower portion holding the microphone connector.
Pull the sound card ribbon cable straight away from its socket on the sound card.
Use your fingernails to pull the microphone connector straight away from its socket on the sound card.
3 участников успешно повторили данное руководство.
