Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Remove your upper case to access the internals of your PowerBook.
Выберете то, что вам нужно
Use your thumbs to push the two battery retaining tabs away from the battery.
The battery should pop up enough to rotate it toward yourself and lift it out of the lower case.
Remove the three 2.3 mm Phillips screws securing the memory cover to the lower case.
Lift the memory cover slightly and pull it toward yourself to remove it from the lower case.
Remove the following ten screws:
Two 14.7 mm shouldered Phillips.
Three 12.3 mm Phillips.
One 3.8 mm T8 Torx.
One 6.8 mm T8 Torx.
Three 1.3 mm Phillips.
Use your fingernails to separate the ZIF cable lock away from its socket. (Move the two brown bits down 1mm)
Remove the four 3.4 mm Phillips screws from the DVI connector side of the PowerBook.
Starting near the display, lift the upper case straight up off the lower case, minding any cables that may get caught.
