Введение
Tripped over your power cord? At least you don't have to replace the entire logic board.
Выберете то, что вам нужно
Locate the battery release tab on the underside of the G4.
Slide the battery release tab to the left and lift the battery out of the computer.
Remove the seven T8 Torx screws from the lower case.
Using your thumbs, slide the lower case toward the front of the computer.
The lower case may stick in the front on a tab just above the center of the optical drive. Be careful as you work the case off, or you may break the thin strip of plastic just above the drive.
Lift the lower case off.
Disconnect the large DC-In connector from the right side of the logic board.
Lift the DC-In board out of the computer by pulling up and away from you.
If there is a fan present, rotate the DC-In board slightly clockwise before easing it out at a slight angle in order to clear the fan clamp on top of it.
4 человек успешно провели ремонт по этому руководству.
