PowerBook G4 Titanium DVI Inverter Replacement
Выберете то, что вам нужно
  1. PowerBook G4 Titanium DVI Inverter Replacement, Battery: шаг 1, изображение 1 из 2 PowerBook G4 Titanium DVI Inverter Replacement, Battery: шаг 1, изображение 2 из 2
    • Locate the battery release tab on the underside of the G4.
    • Slide the battery release tab to the left and lift the battery out of the computer.
  2. PowerBook G4 Titanium DVI Inverter Replacement, Lower Case: шаг 2, изображение 1 из 2 PowerBook G4 Titanium DVI Inverter Replacement, Lower Case: шаг 2, изображение 2 из 2
    • Remove the seven T8 Torx screws from the lower case.
    • Using your thumbs, slide the lower case toward the front of the computer.
    • The lower case may stick in the front on a tab just above the center of the optical drive. Be careful as you work the case off, or you may break the thin strip of plastic just above the drive.
    • Lift the lower case off.
  3. PowerBook G4 Titanium DVI Inverter Replacement, Hard Drive: шаг 3, изображение 1 из 1
    • Disconnect the hard drive ribbon from the logic board using a spudger or the tip of your finger.
  4. PowerBook G4 Titanium DVI Inverter Replacement: шаг 4, изображение 1 из 1
    • To free the hard drive, remove the two T8 Torx screws from the right wall of the battery housing.
    I suspect you are meant to remove the two T8 Torx screws holding down the drive retaining bar on the other side of the hard drive. Once the bar is removed, the drive will pivot out without having to touch the screws on the battery housing wall side.
    John Hagan - Ответить
    I agree with John Hagen. The correct way to remove the hard drive is to remove the two T8 Torx screws and drive retaining bar, then lifting the hard drive up on the side by the optical drive . This will prevent a lot of frustration, and potential damage to the plastic shield underneath the hard drive and the rubber bumpers over the hard drive screws.
    John Nakai - Ответить
    Yes, this is totally better than removing the hard drive screw on the left side of the hard drive as instructed.
    Anthony -
  5. PowerBook G4 Titanium DVI Inverter Replacement: шаг 5, изображение 1 из 1
    • Remove the hard drive by lifting the left edge up and out of the computer.
    • There are four rubber bumpers that fit over the hard drive screws. Ensure that these bumpers come out when you remove the hard drive.
    The hard drive can be removed with its bumpers intact, by just taking off the black plastic clamp to its right. Reinserting the drive is also vastly easier when done this way.
    ratiocination - Ответить
  6. PowerBook G4 Titanium DVI Inverter Replacement: шаг 6, изображение 1 из 1
    • Your laptop should look approximately like this.
  7. PowerBook G4 Titanium DVI Inverter Replacement, Optical Drive Removal: шаг 7, изображение 1 из 1
    • Disconnect and remove the indicated orange ribbon cable.
  8. PowerBook G4 Titanium DVI Inverter Replacement: шаг 8, изображение 1 из 1
    • Disconnect the pink and white inverter cable from the inverter board.
    • The display inverter has orange plastic shielding around it that looks similar to the tape used elsewhere within the computer. Do not remove the shielding from the inverter.
    The pink and white inverter cable connection to the inverter board is very tight. Grasp the notch on the right side of the white connector with needle nose pliers and gently wiggle and pull it out of the socket.
    Sugar Fish - Ответить
  9. PowerBook G4 Titanium DVI Inverter Replacement: шаг 9, изображение 1 из 1
    • Remove the two silver T8 Torx screws from the black plastic bar.
    • Lift the black plastic bar out.
    • Reassembly will be significantly easier if you reseat the hard drive before returning the black bar to its place.
  10. PowerBook G4 Titanium DVI Inverter Replacement: шаг 10, изображение 1 из 1
    • Disconnect the two orange connectors from the logic board, removing tape as necessary.
  11. PowerBook G4 Titanium DVI Inverter Replacement: шаг 11, изображение 1 из 1
    • Lift the drive up on the right side so that you can access and disconnect the modem cable and inverter cable.
  12. PowerBook G4 Titanium DVI Inverter Replacement: шаг 12, изображение 1 из 1
    • Remove the drive by lifting the right edge up and out of the computer.
    During reassembly, make sure pink and white inverter cable with white plug does not get trapped under the edge of the drive unit.
    einar3888 - Ответить
  13. PowerBook G4 Titanium DVI Inverter Replacement, Modem: шаг 13, изображение 1 из 1
    • Remove the two T6 Torx screws from the modem.
    • Lift the modem off the optical drive, carefully guiding the orange ribbon cable through the space in the drive mount.
  14. PowerBook G4 Titanium DVI Inverter Replacement, Inverter: шаг 14, изображение 1 из 1
    • Remove the two T6 Torx screws from the inverter board.
    • Lift the inverter board off the optical drive.
  15. PowerBook G4 Titanium DVI Inverter Replacement: шаг 15, изображение 1 из 1
Заключение
12 участников успешно повторили данное руководство.
Прикрепленные документы
iRobot
Участник с: 09/24/09
1 Репутация
Автор 636 руководств
2 Комментариев
I didn't need to remove the modem on my Antimony model.
Fred Hood - Ответить
Absolutely no reason to remove the HDD, modem, or optical drive to do this on the 1GHz model. Remove the back cover and the two screws that hold the inverter in place, and thats all you need to do.
insaneiaq - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 7
За всё время: 14,548
