Введение
How to remove the hard drive, along with its cable and bracket from your computer.
Выберете то, что вам нужно
Turn the G4 over.
Remove the eight T8 Torx screws from the lower case.
Firmly grasp the plastic tab attached to the Airport card and pull up and to the left.
Disconnect the antenna cable from the left side of the Airport card.
Disconnect the hard drive ribbon from the logic board using a spudger or the tip of your finger, removing tape as necessary.
To free the hard drive, remove the two T8 Torx screws from the right wall of the battery housing.
Remove the hard drive by gently grasping the orange ribbon cable and lifting the left edge up and out of the computer.
4 участников успешно повторили данное руководство.
