Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Remove the battery.
Turn the keyboard locking screw so that it is parallel to the space bar.
Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
Rest the keyboard face down on the trackpad area.
Disconnect the keyboard connector from the logic board.
Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to ÒpopÓ up.
Pull the RAM chip out.
Repeat this process if a second RAM chip is installed.
Turn the G4 over.
Remove the eight T8 Torx screws from the lower case.
Using your thumbs, slide the lower case away from you.
Lift the lower case off.
Firmly grasp the plastic tab attached to the Airport card and pull up and to the left.
Disconnect the antenna cable from the left side of the Airport card.
Disconnect the hard drive ribbon from the logic board using a spudger or the tip of your finger, removing tape as necessary.
To free the hard drive, remove the two T8 Torx screws from the right wall of the battery housing.
Remove the hard drive by gently grasping the orange ribbon cable and lifting the left edge up and out of the computer.
Before continuing, place a soft cloth on your work surface to rest the computer on. Turn the G4 over, making sure the DVD drive doesn't fall out. Place the computer on the cloth.
Bend the silver metal EMI clip so that it is vertical. This part may fall out after removing the DVD drive.
Turn the G4 over.
Disconnect the orange DVD ribbon cable from the logic board using a spudger or the tip of your finger
Remove the DVD drive by lifting the right edge up and out of the computer.
Turn the G4 over.
Using a 5 mm nut driver or needle-nose pliers, remove the hex nut from the modem.
Remove the single T8 Torx screw located near the silver heat pipe.
Disconnect the three indicated connectors from the logic board.
Disconnect the orange PC card cage connector from the logic board.
Turn the G4 over.
Remove the three T8 Torx screws from the logic board.
Disconnect the indicated connectors from the logic board, removing tape as necessary.
Carefully lift the logic board up and pull it away from you.
Remove the logic board from the computer.
Remove the two T8 Torx screws that secure the PC Card cage.
Remove the PC Card cage by pulling it to the right and twisting slightly toward you.
Еще один человек закончил это руководство.
