PowerLead Puto PLD003 Lens Replacement
Выберете то, что вам нужно
  1. PowerLead Puto PLD003 Lens Replacement, Side Panel: шаг 1, изображение 1 из 1
    • Slide the battery eject button open to release the battery door.
  2. PowerLead Puto PLD003 Lens Replacement: шаг 2, изображение 1 из 1
    • With the battery door open, carefully remove all four 5 mm Phillips #1 screws.
  3. PowerLead Puto PLD003 Lens Replacement: шаг 3, изображение 1 из 1
    • Rotate the camera so that the underside is facing up.
    • Remove the four 5 mm Phillips #1 screws.
  4. PowerLead Puto PLD003 Lens Replacement: шаг 4, изображение 1 из 1
    • Place the camera on a flat surface, with its underside facing you.
    • Gently pull up on the side panel to remove it from the camera.
  5. PowerLead Puto PLD003 Lens Replacement, Lens: шаг 5, изображение 1 из 2 PowerLead Puto PLD003 Lens Replacement, Lens: шаг 5, изображение 2 из 2
    • Remove the three 4 mm Phillips #1 screws holding the weight.
    • Remove the weight.
  6. PowerLead Puto PLD003 Lens Replacement: шаг 6, изображение 1 из 1
    • Remove the two 4 mm Phillips #1 screws holding the back panel in place.
  7. PowerLead Puto PLD003 Lens Replacement: шаг 7, изображение 1 из 1
    • Apply pressure to the back panel (away from the camera) to remove.
  8. PowerLead Puto PLD003 Lens Replacement: шаг 8, изображение 1 из 1
    • Set aside back panel for now.
    • Remove the final 4 mm Phillips #1 screw holding the screen in place. It is very small and hard to see.
  9. PowerLead Puto PLD003 Lens Replacement: шаг 9, изображение 1 из 1
    • Carefully apply pressure, away from the camera, to the screen to detach it from the body.
    • The white cord should still be connected to the body.
    • OPTIONAL: Remove the screen to make accessing the lens easier
  10. PowerLead Puto PLD003 Lens Replacement: шаг 10, изображение 1 из 1
    • Unscrew the two 4 mm Phillips #1 screws holding onto the lens casing
    • There are also two 4 mm Phillips #1 screws on the other side holding onto the lens casing, remove them as well.
  11. PowerLead Puto PLD003 Lens Replacement: шаг 11, изображение 1 из 1
    • Pull forward on the lens casing to remove it. The cord connecting the light to the motherboard should still be attached.
  12. PowerLead Puto PLD003 Lens Replacement: шаг 12, изображение 1 из 1
    • Unscrew the three 4 mm Phillips #1 screws holding the plastic lens holder.
  13. PowerLead Puto PLD003 Lens Replacement: шаг 13, изображение 1 из 1
    • Remove the plastic lens holder.
  14. PowerLead Puto PLD003 Lens Replacement: шаг 14, изображение 1 из 1
    • Push the lens out of the plastic casing from the back.
    • Insert new lens into the plastic casing.
Заключение
Justin Tew
Участник с: 03/31/16
767 Репутация
Автор 7 руководств
Команда
Eastern Washington University, Team 1-2, Giguere Spring 2016 Участник Eastern Washington University, Team 1-2, Giguere Spring 2016
EWU-GIGUERE-S16S1G2
4 членов
Автор 7 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 7
За всё время: 170
