Введение
This guide will show you how to remove the PowerLead Puto PLD003 side panel. The removal of the side panel is necessary, in order to, replace most parts.
Выберете то, что вам нужно
Rotate the camera so that the underside is facing up.
Remove the four 5 mm Phillips #1 screws.
Place the camera on a flat surface, with its underside facing you.
Gently pull up on the side panel to remove it from the camera.
Еще один человек закончил это руководство.
