Введение
This guide shows how to remove the screws that hold the camera together, remove the side panel from the camera, and how to remove the tripod clip.
Выберете то, что вам нужно
Rotate the camera so that the underside is facing up.
Remove the four 5 mm Phillips #1 screws.
Place the camera on a flat surface, with its underside facing you.
Gently pull up on the side panel to remove it from the camera.
Еще один человек закончил это руководство.
