Введение
This guide shows how to remove the side panel from the camera, how to remove the back panel, and how to replace the zoom button.
Выберете то, что вам нужно
Rotate the camera so that the underside is facing up.
Remove the four 5 mm Phillips #1 screws.
Place the camera on a flat surface, with its underside facing you.
Gently pull up on the side panel to remove it from the camera.
Remove the 4 mm Phillips #1 screws holding the weight.
Remove the weight.
Carefully apply pressure away from the camera to the screen to detach it from the body.
The white cord should still be connected to the body.
Lift the circuit board out of the plastic casing.
Gently pull on the zoom button to remove it from the circuit board.
