Введение
How to prep a black wire for XYZ job.
Выберете то, что вам нужно
Measure out a 10cm length of wire.
Use a pair of flash cutters to carefully cut through the wire.
Measure 20mm from either end of the wire.
With the flash cutters remove the instulation that is covering the wire.
Your finished wire should now look like this.
Remember to twist of the ends of the wire with your fingers so that the wire strands are not loose.
You are finished.
You are finished.
6 участников успешно повторили данное руководство.
