Введение
Follow this guide to remove or replace the vacuum motor on your Presto Carpet Extractor 9.840-068.0 (2016).
Be sure to thoroughly clean and dry your extractor before you begin.
Выберете то, что вам нужно
If it is still attached, pull and disconnect the brass quick-connect fitting from the carpet extractor body.
Unclasp and release the two black latches on either side of the carpet extractor.
Use a Phillips #2 screwdriver to remove the two 1/2" screws and washers securing the vacuum motor retainer.
Gently pull the vacuum motor up and out of the extractor housing and lay it on its side.
Use a Phillips #2 Screwdriver to remove the 3/8" terminal screw securing the motor's three ground wires.
Use a pair of wire cutters or scissors to cut and remove the zip tie secured around the black, yellow, and green motor wires.
Disconnect the two black motor wires from the switch mounted inside the carpet extractor housing.
5 участников успешно повторили данное руководство.
