Введение
This is a replacement guide for the chute. The chute helps guide the popcorn kernels to a bowl. This repair may be needed if the Chute has been broken over time. Be sure that you are only working on the Presto PopLite 04820 when it is unplugged and it has cooled down.
Выберете то, что вам нужно
Remove the three 49 mm Phillips #2 screws.
Once you have removed the screws, remove the chute from popper base.
Еще один человек закончил это руководство.
