Введение
Shows how to replace the entire power cord. This may need to be done if the device shut off mid-use. Be sure that the PopLite is unplugged from the wall and has had time after use to cool down before working on the device.
Выберете то, что вам нужно
Remove the four 9 mm Phillips #2 screws from the base.
Once all four screws are removed, take the base off.
Locate the plastic piece holding the power cord in place.
Take the metal spudger from the tool kit and pry this piece loose.
Remove the power cord.
Еще один человек закончил это руководство.
