Введение
We disassemble a broken Princess toaster into its most basic elements. We try to damage the least amount of parts possible, so we for example only cut a piece when absolutely necessary.
Выберете то, что вам нужно
Turn the toaster 90 degrees so that you can see the bottom.
Use a crosshead PZ #1 screwdriver to unscrew the bottom left and top right 5 mm crosshead screws.
Use a triangle TA 2.5 screwdriver to unscrew bottom right and top left 5 mm triangular screws.
Unscrew the six 5 mm crosshead screws visible on the plate underneath the bottom plate. Use the same crosshead screw driver you used for the bottom plate.
Unscrew the two 5 mm triangular screws with the triangular screwdriver. Again; use a set of pliers or a pipe wrench to get them loose if you cannot get it done with the screwdriver.
With a long PZ 1 screwdriver, remove the two 4mm screws that connect the plug.
Remove the right side plate partly.
Lift the part attached to the handle at the front of the toaster. Hold this part up.
Unscrew the two 4 mm screws connecting the part of the handle to the core. One screw is located underneath the part you just lifted, the other screw is located at the other side of the toaster.
Remove the electric circuit board from the top cover by unscrewing the two 4 mm screws attaching it. This can be done with the crosshead screwdriver you used before.
Removed the circuit board from the plastic black part holding it by unscrewing the two 8 mm crosshead screws.
To disassemble the core of the toaster, use pliers to twist the 4 metal clips that stick out on each side of the core (so, 8 in total).
Remove the two sides of the core.
Unscrew two 10 mm crosshead screws connected to the bottom of the core to remove the cable.
To remove the cable completely, cut the soldered cables with a cutting tool.
Unscrew the eight 8 mm crosshead screws from the bottom of the core to remove the two legs from the base.
Unscrew the two 10 mm crosshead screws that connect the black wire part to the bottom of the core.
Unscrew the two 10 mm crosshead screws from the white part that is attached to the top of the core.
You can remove the bottom plate from the base by bending the 6 metal clips that stick out. This can be done with a plier or with a flat screw driver.
To further dissamble the toaster you will need to twist more metal clips and break the pop nails that hold the base plate and some other parts together. We did not go further since for repair you will probably not need to disassemble the product further. Therefore this is our final exploded view of our disassembly.
Еще один человек закончил это руководство.
