Princess Compact Blender Rubber Gasket Replacement
Выберете то, что вам нужно
  1. Princess Compact Blender Rubber Gasket Replacement, Rubber Gasket: шаг 1, изображение 1 из 1
    • Lift the glass container of the motor
    • The motor is the bottom part of the blender
    • If your blender has recently been used, you may want to clean it before taking it apart
  2. Princess Compact Blender Rubber Gasket Replacement: шаг 2, изображение 1 из 2 Princess Compact Blender Rubber Gasket Replacement: шаг 2, изображение 2 из 2
    • Unscrew the base from the glass container. The right direction is indicated by the red arrow.
    • The base is the part whereon the blades are attached
  3. Princess Compact Blender Rubber Gasket Replacement: шаг 3, изображение 1 из 1
    • Lift metal blades with the metal hood out of the base
    • Watch out for sharp blades or wear gloves
    • Large rubber ring may fall out of the base, this is no problem, just put it back in place
  4. Princess Compact Blender Rubber Gasket Replacement: шаг 4, изображение 1 из 2 Princess Compact Blender Rubber Gasket Replacement: шаг 4, изображение 2 из 2
    • Take the cutting blades in one hand and the black, plastic connector part in the other
    • This is where you could use the gloves
    • Unscrew the latter together with the screw-nut from the axis by twisting
    • If necessary, apply a little force to slightly pull it out
    • To unscrew, you have to twist right. The “righty tighty, lefty loosy-principle” does not apply here
  5. Princess Compact Blender Rubber Gasket Replacement: шаг 5, изображение 1 из 1
    • Gently slide off the hood and lower, small metal protective ring from the axis and don’t lose the rubber ring!
  6. Princess Compact Blender Rubber Gasket Replacement: шаг 6, изображение 1 из 2 Princess Compact Blender Rubber Gasket Replacement: шаг 6, изображение 2 из 2
    • Slide the broken ring off the axis
    • Replace the broken ring for a new one
  7. Princess Compact Blender Rubber Gasket Replacement: шаг 7, изображение 1 из 3 Princess Compact Blender Rubber Gasket Replacement: шаг 7, изображение 2 из 3 Princess Compact Blender Rubber Gasket Replacement: шаг 7, изображение 3 из 3
    • Slide the remaining parts back on the axis in the following order:
    • Metal hood
    • Small metal protective ring
    • Black plastic connector
    • Screw back the screw-nut on the thread with the pliers to fasten the assembly
    • Put the blade-assembly back in the base
  8. Princess Compact Blender Rubber Gasket Replacement: шаг 8, изображение 1 из 3 Princess Compact Blender Rubber Gasket Replacement: шаг 8, изображение 2 из 3 Princess Compact Blender Rubber Gasket Replacement: шаг 8, изображение 3 из 3
    • Twist the base back onto the glass container
    • Put the glass container on the stand (bottom part of the blender, containing the motor)
    • Start making your smoothie!
Заключение
marieke.vandijk
Участник с: 03/08/17
101 Репутация
1 руководство автора
Команда
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 5
За последние 30 дней: 38
За всё время: 3,002
