Введение
If your device will not turn on at all, use this guide to replace your dead or dying battery and make your device functional again.
Выберете то, что вам нужно
Remove both 4 mm screws on the top of the tablet with a PH00 screw driver.
Using the flat end of a spudger, carefully separate the battery from the base of the device.
3 участников успешно повторили данное руководство.
2 Комментариев
How will I know if my proscan tablet battery is no good once I remove it
