Введение
If your ProScan's audio is not working, use this guide to replace the speakers. This guide will require soldering.
Выберете то, что вам нужно
Remove both 4 mm screws on the top of the tablet with a PH00 screw driver.
Pull back the protective tape from the two wires that connect the speakers to the motherboard.
If needed use a plastic opening tool to remove speaker from the speaker port on the tablet.
Заключение
