Problem with navigation in the Android System Recovery menu
Видеообзор
  1. Problem with navigation in the Android System Recovery menu, Problem with navigation in the Android System Recovery menu: шаг 1, изображение 1 из 3 Problem with navigation in the Android System Recovery menu, Problem with navigation in the Android System Recovery menu: шаг 1, изображение 2 из 3 Problem with navigation in the Android System Recovery menu, Problem with navigation in the Android System Recovery menu: шаг 1, изображение 3 из 3
    • Open the Android System Recovery menu.
    • You can find the manual how to do this here.
    • If your tablet is stuck on the Android robot with exclamation mark picture, press the Volume Up or Down button.
    • Now, if the cursor is on "reboot system now", press the Volume Down key twice to go to "apply update from external storage", and just once to go to "wipe data...".
    • The cursor will stay on "apply update..." but the real selection will be "wipe data / factory reset".
    • Press the Power On button to select it. In the next menu you must choose "Yes - erase all user data".
    • Use the same technique to choose it. And finally, "reboot system now".
  2. Problem with navigation in the Android System Recovery menu: шаг 2, изображение 1 из 2 Problem with navigation in the Android System Recovery menu: шаг 2, изображение 2 из 2
    • If the cursor is on "Apply update from ADB", press the Volume Down key twice to go to "wipe data/factory reset" and choose it with the Power On button.
    • On the next screen press press the Volume Down 3x to go steb before "Yes --delete all user data".
    • Press another one time the Volume down button. The cursor will not move, but actually you are on the "Yes -- delete all user data" and you can select it with the Power On button.
    • Did you do it successfully?
Заключение
36 человек успешно провели ремонт по этому руководству.
ZFix
Участник с: 12/09/13
195 994 Репутация
Автор 330 руководств
Команда
Master Techs Участник Master Techs
Community
329 членов
Автор 1 452 руководств
13 Комментарии к руководству
When i factory reset through the Android system recovery menu, i can't navigate normally.
I fix it now,thank you very much!
AndroidDataRecovery - Ответить
Fix all data. System
Macky Villanueva -
I can't do it it just does up with a different thing
irirangihammond - Ответить
Wow I did not know this.ill try this way and thanks for the benifit
issammax147 - Ответить
I got to the page where I gave to select yes but it jumps 2 spaces up and down and jumps past the yes option. How can I do it
Brittany - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 15
За последние 30 дней: 61
За всё время: 75,430
