Processor of why! Replace W253EU
Выберете то, что вам нужно
  1. Processor of why! Replace W253EU, Battery from why! Remove W253EU: шаг 1, изображение 1 из 3 Processor of why! Replace W253EU, Battery from why! Remove W253EU: шаг 1, изображение 2 из 3 Processor of why! Replace W253EU, Battery from why! Remove W253EU: шаг 1, изображение 3 из 3
    • Turn off the computer.
    • Before each operation it is important to start with the removal of the accumulator.
    • Take the slide unlocked into position, remove the battery.
  2. Processor of why! Replace W253EU, Access to RAM and CPU from why! W253EU: шаг 2, изображение 1 из 2 Processor of why! Replace W253EU, Access to RAM and CPU from why! W253EU: шаг 2, изображение 2 из 2
    • Using a Philips #1 screwdriver, unscrew the 5 screws securing the cover.
  3. Processor of why! Replace W253EU: шаг 3, изображение 1 из 3 Processor of why! Replace W253EU: шаг 3, изображение 2 из 3 Processor of why! Replace W253EU: шаг 3, изображение 3 из 3
    • Push the screwdriver a few millimeters under the cover so that it can be touched with your fingers.
    • Now lift the cover carefully.
    • Attention! Disconnect the ventillator cable so that the cover can be completely removed (see next step).
  4. Processor of why! Replace W253EU: шаг 4, изображение 1 из 1
    • Since the ventillator is mounted under the cover, its power supply cable must first be disconnected so that the cover can then be completely removed.
  5. Processor of why! Replace W253EU, processor: шаг 5, изображение 1 из 3 Processor of why! Replace W253EU, processor: шаг 5, изображение 2 из 3 Processor of why! Replace W253EU, processor: шаг 5, изображение 3 из 3
    • Using the Phillips # 1 screwdriver, unscrew the 3 mounting screws of the processor heat sink.
    • Note position of marker triangle as this will determine the positioning of the processor during replacement.
    • Unlock the coupling system of the processor with a classic screwdriver.
    • Make sure that you do not remove the heat-dissipating paste between the processor and the heat sink, as this is the only way to ensure that the processor is properly cooled.
  6. Processor of why! Replace W253EU: шаг 6, изображение 1 из 3 Processor of why! Replace W253EU: шаг 6, изображение 2 из 3 Processor of why! Replace W253EU: шаг 6, изображение 3 из 3
    • Carefully disconnect the processor from its holder.
    • Now place the processor aside, taking into account the position of the triangle.
Заключение
For reassembly, follow the instructions in the reverse order
Особая благодарность этим переводчикам:
de en
100%
Эти переводчики помогают нам починить мир! Хотите внести свой вклад?
Начните переводить ›
Felice Suglia
Участник с: 06/15/13
30 731 Репутация
Автор 261 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 399
