ProntoTec Axius Battery Replacement
Выберете то, что вам нужно
    1. ProntoTec Axius Battery Replacement, Battery: шаг 1, изображение 1 из 1
      • Make sure the device is completely turned off before you begging taking it apart to avoid electrocution risks.
      • Place the tablet face-up on a flat table
      Спросите у FixBot
      Добавить комментарий
    2. ProntoTec Axius Battery Replacement: шаг 2, изображение 1 из 1
      • Starting near the headphone port, fit the flat end of the spudger in between the screen and back case.
      • Pry the back case from the screen around each point on the device to release the clips securing the case halves to each other.
      Спросите у FixBot
    3. ProntoTec Axius Battery Replacement: шаг 3, изображение 1 из 1
      • Gently remove the back case of the device and lay it in a flat surface as shown in the photo.
      • Make sure not to sever the wires (red and black) connected to the speaker that is located in the back case.
      Спросите у FixBot
    4. ProntoTec Axius Battery Replacement: шаг 4, изображение 1 из 1
      • Using a spudger remove all the tapes that touches the battery.
      • Be careful not to cute any wires that are under the tapes
      Спросите у FixBot
    5. ProntoTec Axius Battery Replacement: шаг 5, изображение 1 из 1
      • Using a soldering iron, heat up the contact point of the red wire from the battery and the motherboard.
      • When the solder begins to melt, use pliers to gently pull the wire from the motherboard
      • Don't leave the soldering iron too long on top of the wire so it doesn't melt any other component in the motherboard or surrounding the area.
      Спросите у FixBot
    6. ProntoTec Axius Battery Replacement: шаг 6, изображение 1 из 1
      • Repeat Step 5 on the black wire connecting the battery to the motherboard as shown in the photo.
      Спросите у FixBot
    7. ProntoTec Axius Battery Replacement: шаг 7, изображение 1 из 2 ProntoTec Axius Battery Replacement: шаг 7, изображение 2 из 2
      • Using a spudger, gently pry the battery from the back of the screen to remove it from the device.
      Спросите у FixBot
Заключение
Antonio Irons
Участник с: 10/20/16
441 Репутация
Автор 4 руководств
Команда
UMass Dartmouth, Team 5-3, Martin Fall 2016 Участник UMass Dartmouth, Team 5-3, Martin Fall 2016
UMASSD-MARTIN-F16S5G3
3 членов
Автор 10 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 4
За последние 30 дней: 24
За всё время: 606
