Введение
Sometimes through typical wear and tear, your grill may not want to start right. If you live in an area where you don't use it year round after a period of time, it doesn't want to start correctly, It could be numerous things. This guide shows the most common isuses that could prevent a grill front starting or running properly, from the battery in the igniter to the propane hose and regulator.
Выберете то, что вам нужно
Completely close the propane tank by turning the valve on the top clockwise. This prevents propane from leaking during the replacement.
Turn the knob on the hose counter clockwise to disconnect it from the tank.
Find the electric igniter on the grill and turn it counter clockwise to reveal one AA battery.
Replace the old battery with a new one.
Locate the orifice that connects the base of the grill and the hose to one another.
Conncected to the orifice should be a nut. Use the crescent wrench to turn the nut counter clockwise and remove the hose from the base.
Begin hand tightening the new hose to the nut that is connected to the orifice.
Once it has been adequately hand tightened use the crescent wrench to finish securing it to the orifice.
3 участников успешно повторили данное руководство.
2 Комментариев
I have a Napoleon travel series P285Q X. Do I need to purchase a control valve with a hose to convert from a 1 - 20 lb tank?
Question. Do I need to purchase a pressure valve and a hose to convert from a 1 lb to a 20 lb tank. The bbq is a Napoleon 285 pro series travel.
