Propane Grill Regulator & Hose Replacement
Выберете то, что вам нужно
  1. Propane Grill Regulator & Hose Replacement, Battery, Regulator & Hose: шаг 1, изображение 1 из 2 Propane Grill Regulator & Hose Replacement, Battery, Regulator & Hose: шаг 1, изображение 2 из 2
    • Completely close the propane tank by turning the valve on the top clockwise. This prevents propane from leaking during the replacement.
    • Breathing in or swallowing propane can harm your health.
    • Turn the knob on the hose counter clockwise to disconnect it from the tank.
  2. Propane Grill Regulator & Hose Replacement: шаг 2, изображение 1 из 2 Propane Grill Regulator & Hose Replacement: шаг 2, изображение 2 из 2
    • Find the electric igniter on the grill and turn it counter clockwise to reveal one AA battery.
    • Replace the old battery with a new one.
  3. Propane Grill Regulator & Hose Replacement: шаг 3, изображение 1 из 1
    • Locate the orifice that connects the base of the grill and the hose to one another.
    • An orifice is a valve commonly found on gas powered home products. This allows the gas to pass through from the source (i.e the propane tank) and burn properly.
    • Conncected to the orifice should be a nut. Use the crescent wrench to turn the nut counter clockwise and remove the hose from the base.
  4. Propane Grill Regulator & Hose Replacement: шаг 4, изображение 1 из 2 Propane Grill Regulator & Hose Replacement: шаг 4, изображение 2 из 2
    • Begin hand tightening the new hose to the nut that is connected to the orifice.
    • If you over tighten the bolt or do not hand tighten it first, you could cross thread the orifice and create more problems for the grill.
    • Once it has been adequately hand tightened use the crescent wrench to finish securing it to the orifice.
Заключение
3 участников успешно повторили данное руководство.
Evan Jureski
Участник с: 03/16/17
141 Репутация
1 руководство автора
Команда
Missouri Western, Team S40-G12, Kunkel Spring 2017 Участник Missouri Western, Team S40-G12, Kunkel Spring 2017
MWSU-KUNKEL-S17S40G12
1 член
Автор 2 руководств
2 Комментариев
I have a Napoleon travel series P285Q X. Do I need to purchase a control valve with a hose to convert from a 1 - 20 lb tank?
Rob Fillion - Ответить
Question. Do I need to purchase a pressure valve and a hose to convert from a 1 lb to a 20 lb tank. The bbq is a Napoleon 285 pro series travel.
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 12
За последние 30 дней: 64
За всё время: 6,168
