Введение
This guide will help you to replace the joysticks in the remote controller for your Gyro-X. You may need to do this if you dropped the remote and broke or jammed the joysticks. The many screws holding the remote case together are set deep in the case, so you will need a long, narrow screw driver to remove them.
Выберете то, что вам нужно
With the joysticks facing up, lift up the top of the remote casing to remove it.
While holding the remote down with one hand, pull the joystick up with the other hand to remove it.
Еще один человек закончил это руководство.
