Введение
After rough flights the stabilizer beam may end up getting damaged. Without a working stabilizer beam, the gyro-copter will not fly as it should. The best way to fix this is by replacing the stabilizer beam completely.
Выберете то, что вам нужно
Pull up on the stabilizer assembly to remove it completely from the drive shaft.
Еще один человек закончил это руководство.
