Введение
This guide provides the steps needed to open and access the components within the remote control, specifically the Trim Rocker Switch.
Выберете то, что вам нужно
Remove the four (4) 8.5mm screws from the body of the remote using a JIS #1 screwdriver.
Remove the two (2) 4mm screws from the handle using a JIS #1 screwdriver.
Open remote body lifting back a full 180 degrees from face.
Remove the four (4) 6mm screws attaching the motherboard to body of the controller using a JIS #1 screwdriver
Gently lift the motherboard backwards.
