Введение
This guide is for replacing the Protocol Dronium Two. Included in your box should be four replacement blades. Do this repair in a clean and well lit place because the rotor blade screw is very small and easy to lose.
Выберете то, что вам нужно
Using the Phillips screwdriver included with the drone, carefully remove the 4.02 mm rotor blade screw.
Once the screw is removed, remove the rotor blade by lifting the blade straight off of the drone
Еще один человек закончил это руководство.
