Введение
Is a motor on your drone spinning but not causing the propeller to spin? Replacing the pinion gear as shown in this guide may help.
Выберете то, что вам нужно
Use the heavy duty spudger tool to pry off metal caps by pushing the spudger up into the cap.
Twist the white spindle sleeve counter clockwise to align locking pin inside with the opening.
Remove Blade Guards by unscrewing two 13 millimeter screws using Philips #0. Pull out the guards. Repeat the steps for the other three corners.
Unscrew two 9 mm screws located inside the legs. Repeat the same procedure for the other three legs
Unplug the camera wire.
Press the hold release button and slide out the camera module away from the button.
Remove the motor protection cover by unscrewing two 9 mm screws using Philips #0. When the screws are off, use your fingers to pull the motor protection cover off. Repeat the procedure for the other three arms.
Unclip the motor cable from the shells housing using two pry tools. Repeat the same procedure for the other three arms.
Remove 3 9mm screws around the motor housing. Repeat the steps for the three other arms.
Remove four 9 mm screws located where the legs originally are placed. (Use a thin head screwdriver)
Cut the yellow strips using a scalpel. Pry open the casing using pry tools working gently around the corners.
