Введение
This guide will walk you through how to separate the upper and lower housing units of the drone. Minimal tooling is required; however, prerequisite steps are required. This guide is useful for accessing internal components of the drone.
Выберете то, что вам нужно
Remove the chrome shaft cover by lightly pulling it away from the drone.
Using a Phillips #000 screwdriver, remove the 7mm screw from the propeller stop.
Remove the 8mm long Phillips #0 screws (24 total) from the lower housing unit.
Separate the upper and lower housing units by lightly pulling the two housing units apart.
