Введение
This guide will walk you through how to remove the pinion gear from the motor shaft. Minimal tooling is required on the prerequisite steps, but removing the pinion gear itself requires no tools. Removing the pinion gear is very easy and should only take a few seconds to complete.
Выберете то, что вам нужно
Remove the chrome shaft cover by lightly pulling it away from the drone.
Using a Phillips #000 screwdriver, remove the 7mm screw from the propeller stop.
Remove the 8mm long Phillips #0 screws (24 total) from the lower housing unit.
Separate the upper and lower housing units by lightly pulling the two housing units apart.
Lift the pinion gear off the motor shaft by lightly pulling it away from the drone.
2 Комментариев
where can i get pinion gears at
where can i purchase pinion gears
