Protocol Kaptur GPS Main Circuit Board Replacement
Выберете то, что вам нужно
  1. Protocol Kaptur GPS Main Circuit Board Replacement, Battery: шаг 1, изображение 1 из 2 Protocol Kaptur GPS Main Circuit Board Replacement, Battery: шаг 1, изображение 2 из 2
    • The battery is accessible through the back of the drone.
    • Press the tabs on both sides of the white stripe to pull the battery out.
  2. Protocol Kaptur GPS Main Circuit Board Replacement: шаг 2, изображение 1 из 3 Protocol Kaptur GPS Main Circuit Board Replacement: шаг 2, изображение 2 из 3 Protocol Kaptur GPS Main Circuit Board Replacement: шаг 2, изображение 3 из 3
    • Remove the screws starting with the three smaller ones on the top part of the battery.
    • Remove the three screws on the other side.
    • There are two screws tucked under where the yellow circle is located. You will need to remove the other screws first before you get to these two.
    • There should be one 7 mm Phillips head screw, three 6 mm Phillips head screws, and four 5 mm Phillips head screws.
  3. Protocol Kaptur GPS Main Circuit Board Replacement: шаг 3, изображение 1 из 2 Protocol Kaptur GPS Main Circuit Board Replacement: шаг 3, изображение 2 из 2
    • Remove the top piece, and gently pry the two halves apart. Divide the sticker if necessary.
  4. Protocol Kaptur GPS Main Circuit Board Replacement: шаг 4, изображение 1 из 2 Protocol Kaptur GPS Main Circuit Board Replacement: шаг 4, изображение 2 из 2
    • The battery is now removable from its container.
    • During reassembly, make sure the outlet is returned to its holder and faces the correct direction.
  5. Protocol Kaptur GPS Main Circuit Board Replacement, Main Circuit Board: шаг 5, изображение 1 из 2 Protocol Kaptur GPS Main Circuit Board Replacement, Main Circuit Board: шаг 5, изображение 2 из 2
    • Remove the 4x 7mm screws on the top and bottom, and the 2x 5mm screws from the middle, then remove the back part of the housing.
    • Remove the two hidden screws at the bottom, and the white power button.
    • There will be 6x 7 mm Phillips head screws, and 2x 5 mm Phillips head screws.
  6. Protocol Kaptur GPS Main Circuit Board Replacement: шаг 6, изображение 1 из 3 Protocol Kaptur GPS Main Circuit Board Replacement: шаг 6, изображение 2 из 3 Protocol Kaptur GPS Main Circuit Board Replacement: шаг 6, изображение 3 из 3
    • Unplug all the cords from the circuit boards.
    • Carefully slide the main body right off the arms.
  7. Protocol Kaptur GPS Main Circuit Board Replacement: шаг 7, изображение 1 из 2 Protocol Kaptur GPS Main Circuit Board Replacement: шаг 7, изображение 2 из 2
    • Remove the four 4mm Phillips screws.
    • Desolder all cords on the circuit board, and pull the board up and out.
    • It is important to keep track of where the leads came from. Red/Blue and Black/White pairings belong to motors, whereas Black/Red pairings belong to lights. The ports are labeled on the board.
Заключение
Еще один человек закончил это руководство.
Connor Woitte
Участник с: 02/15/18
858 Репутация
Автор 3 руководств
Команда
UW Stout, Team S8-G6, Ogden Spring 2018 Участник UW Stout, Team S8-G6, Ogden Spring 2018
UWSTOUT-OGDEN-S18S8G6
3 членов
Автор 4 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 7
За последние 30 дней: 8
За всё время: 772
