Выберете то, что вам нужно
With the drone flat on the ground, identify which propeller guard you will be replacing.
With the plastic opening tool, pry the side of the guard closest to the front or the back of the drone depending on where you decided to start from.
After prying off one side of the guard, pushing down on the same side will release the other side of the clip.
With the replacement guard line up the clips and push the clips into place.
After the guard has been attached to the drone, pinch the clips as you push the guards to ensure they are secured.
