Protocol Slipstream WiFi Propeller Guards Replacement
Выберете то, что вам нужно
  1. Protocol Slipstream WiFi Propeller Guards Replacement, Propeller: шаг 1, изображение 1 из 1
    • Remove the 4.5 mm Philips #00 screw that holds the propeller in place.
  2. Protocol Slipstream WiFi Propeller Guards Replacement: шаг 2, изображение 1 из 1
    • Lift the propeller off the device
    • Note: When sliding on the new propeller, make sure to align the groove on the propeller with the shaft of the gear. If aligned correctly the propeller should slide on smoothly.
    • There are two different propellers that go on the device. Each propeller has a 3 or 4 written on it. Be sure to replace the propeller with a new propeller with the matching number.
  3. Protocol Slipstream WiFi Propeller Guards Replacement, Propeller Guards: шаг 3, изображение 1 из 1
    • There are 3 points where the propeller guard attaches to the device.
    • Place one finger on the body (black object) of the device and one finger under the propeller guard (silver object) and gently but firmly push the propeller guard up until it disconnects from the body at the 3 points circled in red.
    • There are two propeller guards on the device. One for each set of propellers. Each propeller guard has two locations that you have these 3 tabs to remove until you can replace it.
Заключение
John Burkee
Участник с: 09/17/19
445 Репутация
Автор 4 руководств
Команда
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 11
За всё время: 165
