Введение
Use this guide to disconnect the battery from the your Protocol TerraCopter Evo. You will need to flip your drone upside down then unlock the battery cover by pulling the plastic trigger down and open it then remove it by disconnect it from the drone's cable.
Выберете то, что вам нужно
Pull down the battery cover on the bottom of the drone and open it.
Pull the battery out of the battery slot.
Disconnect the red battery cable from the device.
