Введение
The Protocol Vento drone has four motors. Each motor is located at the base of one of the drone's four arms. This guide will demonstrate how to remove and replace a motor.
Выберете то, что вам нужно
Use a moderate amount of force to pry the propeller out of its base. The propeller should pop off.
Unscrew the 4.9mm Phillips #000 screw that is located at the end of the drone's arm.
Hold the base of the arm while gently pulling the motor cover away from the arm.
Инструмент, используемый на этом этапе:Tweezers$4.99
Grasp the clip’s edges with a pair of tweezers and pull outward.
4 человек успешно провели ремонт по этому руководству.
2 Комментарии к руководству
Please send me motor description
send me protocol vento motor
